New Consumer Unit Needed? | on ElectriciansForums
Discuss New Consumer Unit Needed? in the UK Electrical Forum area at ElectriciansForums.net
Colin33
Cornwall
I've been asked to do some work on a domestic installation. However, it seems all but the shower and garage supply are not RCD protected. Does anyone know if single module rcbo's are available for this Merlin Gerin board or is it gonna have to be changed?
[ElectriciansForums.net] New Consumer Unit Needed?
Look for Schneider C60H RCBO.
Seems to be a lot of C curve MCBs in there for a domestic board.
I could only find Schneider ones which don't look like they'll fit (wrong way up) Yes they're C types, think who ever did this was probably more accustomed to industrial work. A metal Cu in a domestic premises before AM3?? Whatever next?
Try and get the Schneider C60H range, the iC60H will fit but not perfectly as they are slightly narrower and a bit taller.
What is wrong with a Type C in a domestic.
Absolutely nothing as long as the disconnection times are met and fault current is sufficient to trip them. I'd much prefer to work on that board than some of the modern options available.
Thanks for your help guys. A quick google and 6 of these RCBO's will cost around ÂŁ216, which is about what a new loaded CU with 8 rcbo's would cost. But labour will be a lot less of course...
Reply to New Consumer Unit Needed? in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
