New cooker dp switch, existing wires won't reach terminals.. | Page 2 | on ElectriciansForums
Discuss New cooker dp switch, existing wires won't reach terminals.. in the UK Electrical Forum area at ElectriciansForums.net
Deuce
Stamford
Evening all,
Not a qualified spark so I thought it better to ask than make assumptions.
Swapping all switches/sockets in our house to screwless ones, all going fine until I went to swap the cooker isolator switch. The old one has feed top, load bottom. The new one has load top, feed bottom. As such, the wires won't reach their intended terminals, and there is no way of reconfiguring the switch assembly to reverse it internally and leave the "on/off" the right way round on the front.
I'm pretty sure the obvious answer is to extend the cabling in the back box, but wanted to check the best way to do this. Can I just crimp and shrink using any suitably rated crimps?
Thanks in advance
If no neon then it's just a basic double pole switch. Scratch off supply and load labels if you like. If someone else ever works on it they should be proving dead before working on it. Otherwise they are not competent to work on it.
I would label the cables clearly and indelibly e.g. with P-Touch flags, maybe even stick a label in the backbox saying what has been done, and connect line to load and vice versa. If you do decide to extend, and Wagos don't fit nicely, don't rely on commodity grade yellow crimps (which would be smallest). Use proper ones with a published spec, and make sure the tool suits.
You could also put a sticker on the cu stating that the cooker connections are reversed at the switch.
Reply to New cooker dp switch, existing wires won't reach terminals.. in the UK Electrical Forum area at ElectriciansForums.net
So much for trying to steer this back on track.
2 3
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
