new house 3phase heat pump | on ElectriciansForums
Discuss new house 3phase heat pump in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
new house guys with a new heating system through mcs real scheme
3 phase supply run into house the pump is the only piece of equipment requiring 3phase ,
question is looking for best way to do this was thinking give the house itself the normal dual rcd db then from 3phase mains to lucy blocks fuse down for pump.
pump is situated in the same location as main cable head ,
4kw 32a 3phase supply required via rotary isolator
any views ?
If you have a three phase supply you really have to balance the phases, (I mean REALLY) So the single phase board and 3 phase switchfuse idea is out. The only way to do this is a 3 phase DB with rcbo's.
You will need to consider how to split the load, how tot make sure the accessories/equipment of circuits on different phases don't end up with touching distance of each other etc. etc.
You could maybe make your client get a single phase supply for the house and 3 phase supply just for heat pump?
theres already one house on estate thats done the way i described although i havent seen it yet , the pump is only 4kw , the house only has sockets lights and cooker no electric showers etc and all led lighting , i cant see there being much of a problem doing it that way
I'm sure something more appropriate could be sorted out for a domestic central heating pump. Sounds way over the top, to me.
Basic tp+n db like maybe a 4way, taking the main supply and has a breaker for the pump. (possibly then into an adjoining enclosure like a 4 module Sentry, for RCD, if required.)
Then a sp 63a mcb on L2 to feed a consumer unit also adj.
4 ways used and 8 permanent blanks.
Reply to new house 3phase heat pump in the UK Electrical Forum area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
