View the thread, titled "new light fitting blowing breaker" which is posted in Australia on Electricians Forums.
K
kyranocat
hi guys hoping to get some advice, our porch light has been removed as the entire porch is being redone but the 2 cable feeds were not identified i have checked polarity on one and i am certain this is the switch wire leaving the second cable as a mains feed cable .The problem is every time i wire a light onto these cables the circuit breaker trips as soon as the light switch is clicked into the on position.I am lost on what the issue might be.Polarity has been confirmed on the switch wire so thats correct and the mains cable turns live then the breaker is in the on position aswell.I dont think its an overloaded circuit either as both lights are the same wattage and even tried wiring the old light back on to check (SAME SITUATION OCCURS).
I am hoping someone might be able to shed some light on the situation(no pun intended).Thanks
i was suspicious about if i had correctly identified the switch so on top of using a continuity/polarity indicator i have nicked a MFT from someone to test the continuity and it does confirm its the switch wire. got a reading and then flipped the switch to get an open circuit so i am going to try testing the circuit more indepth later in the week.I am wondering if i should try and replace the switch to see if its the issue, will post back later with an update.
not sure if this would be considered good practice, but have you tried connecting the incomming live and neutral to the lamp connectors directly missing out the switch and switch wire altogether to see if that trips the breaker.
I’m sorry but two cables doesn’t give a lot of options.
If you’ve borrowed a MFT do you know how to use it?
A competent electrician will find the fault within ¼ hour.
If building modifications have been done the chance is cable damage!
Reply to the thread, titled "new light fitting blowing breaker" which is posted in Australia on Electricians Forums.
