Hi, welcome to the forum.
When you get an Error 5 (excessive noise) warning when making EFLI or RCD measurements with a Fluke 165x series MFT the tester stores the reading, this can be displayed by pressing the down arrow key as you have found, however the tester is warning you that this value is degraded by noise and it's accuracy can't be relied on. You should ensure all noise sources (appliances) are isolated on your board and any sub-boards, if you are working on site ensure any welders and large motors are isolated and locked off where possible as these are primary high noise sources. Sometimes you just have to 'bite the bullet' and retest at another time when the noise on the network is lower, e.g. you have garage down the road welding car parts, testing in the evening after normal garage hours or during their dinner hour should allow good measurements to be made.
