New shed circuit tripping RCD at house consumer unit | Page 4 | on ElectriciansForums
Discuss New shed circuit tripping RCD at house consumer unit in the UK Electrical Forum area at ElectriciansForums.net
solgen
Hi,
I've recently run 4mm 4 core SWA from a 20A MCB house consumer unit to a garage unit installed in a shed 50M away. The garage unit has 16A and 6A breakers protected by 40A 30mA RCD main switch. All wiring connections seem to be correct, however, as soon as anything is placed under load either from socket or light, the RCD back at the house consumer unit trips. I have visually inspected everthing so far and cannot see any problems.
I looked for neutral problems and cannot see anything amiss.
Can anyone suggest where the problem maybe?
Don't need 2 RCDs not unless the shed feed is from a non RCD side of the CU, in this case it looks very doubtful that it is, as the house RCD is tripping
Its not on the house rcd.
Don't think the OP is a Sparky
Like you were once im new and fault finding is a learn as you go. unless your a microwave electrician
Reply to New shed circuit tripping RCD at house consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
