I currently have a double socket in our spare bedroom and a 4 way extension block running a computer and peripherals. For neatness I would like to have an electrician add a second double socket right next to the existing one and do away with the extension block. The socket can be added to the existing ring main.
However a neighbour told me that if I have any electrical work like this done then I may be required by regulations to have my consumer unit updated as it is a fuse wire unit, not RCD.
I could understand an upgrade requirement if a new circuit was being added but not for a trivial modification like this surely?
(I do understand the safety benefits of RCD over fuses, I just want to be clear on whether an upgrade would be mandated as my neighbour suggests.)
Thanks for any help.
Whilst I can't criticise (perhaps not the right word), I can't whole heartily agree with everything that's been said.
If you asked me to install a new socket without RCD protection (even though existing adjacent have none). I would decline. The RCD protection is there for good reason. Even though your trailing lead has none either, I don't understand peoples mindset, when they want to change something for 'neatness', but do not wish to consider safety.
Another issue I wish to comment on; there will be some here, who say there is nothing wrong with a rewire-able fuse board (consumer unit) and they would be correct. But it is also an indication of the age of your electrical installation. I would recommend considering having a (free) quotation for a new consumer unit, and perhaps an inspection of the remainder of your installation.
I see that you can afford 'computers & peripherals', but it seems you don't have money to spend on a safety upgrade to your property. A motor vehicle is required to have a annual safety check after three years of age, but a domestic electrical installation can go for decades without inspection, other than DIY alterations.
It is easy for me, perhaps to pontificate as the cost to me as an electrician would be small, but I would follow your neighbours nontechnical, but sensible advice.
My opinion.
