New to the forum, 100a main switch problem | Page 3 | on ElectriciansForums
Discuss New to the forum, 100a main switch problem in the The Welcome Forum area at ElectriciansForums.net
Take Tel's advice. That should be reconfigured as it was. It's a pretty awful job, admittedly not helped by the choice of CU brand.
The replacement of a consumer unit also needs fully testing, a certificate producing, and notification to building control.
Thanks for coming back to update the thread. If you can take criticism on the chin and learn from it you'll learn a lot here.
Reply to New to the forum, 100a main switch problem in the The Welcome Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
