New wiring colours | Page 2 | on ElectriciansForums
Discuss New wiring colours in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
Can't understand how experienced sparks do this
[ElectriciansForums.net] New wiring colours
I always sleeve or tape the numbered cores as you can't guarantee how different sparks will connect them. I use 1-3 as L1-L3, 4 neutral & 5 earth, but some one else may think the earth is most important so should be core 1!
If its someone elses work. Check both ends, trust know one.
Cable IDs and the way there interpreted are in the eye of the beholder, (sad but true)
I came across multi core sleeved green and yellow one end and connected to the neutral the other.
Sh*t happens.
Regardless of the chat about what colours to use, anyone connecting a black as a neutral with modern colours should be dismissed immediately IMO, nothing else to add :tongue3:
Reply to New wiring colours in the UK Electrical Forum area at ElectriciansForums.net
Apart from ripcord and maybe a speciality flat elevator type ribbon cable I've also never seen a cable with two identical blue wires. I highly...
It would certainly heat up faster at 240V! I have a large 240-120V transformer to power my American kitchen appliances here.
