I'm replacing an old MEM Fuse Board in my garage with a Small CU. The power was supplied from the ground floor ring main, so I've removed that and added a separate circuit in the main CU with its own RCBO. Problem is, the RCBO trips every time I turn something on and I can't understand why. Apart from the supply cable - main CU to new CU - the cabling is exactly the same as yesterday and was working so I can't understand why there's a problem. Help desperately needed as I have 3 freezers in the garage.
