NICEIC’s Connection magazine (using CPC as a live conductor)? | on ElectriciansForums
Discuss NICEIC’s Connection magazine (using CPC as a live conductor)? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
BigSi
Cornwall
I was reading the latest issue of the NICEIC’s Connection magazine, when came across an article about wiring extractor fans. I didn’t read it in depth (was in the library at the time!!!), but from what I can gather you can now use the cpc in a flex (flex only, not hard wired) as a live conductor from the connection point to the fan.
It refers to changing a fan for a unit with a timer, and the now sleeved cpc can be used as a live cable (presumably the switched feed)? But I couldn’t quite figure out how this would be of benefit as it’s still connected to the connection point which when I looked last only had one live in, one live out.
Or have I totally missed the point altogether? :stupid:
I think you have.
Its refering that you can use the green and yellow core wthin a flex as a live/neutral conductor, as long as you flag it thus at both ends. But certainly not a cpc within a twin and earth cable, as it would only be single insulated and carrying a voltage over 50 volts and not satisfying basic protection.
As most fans are class II/double insulated/reinforced insulated, they don't require to be connected to earth, and as most modern fans incoroporate a run on timer. It will save having to rewire them with 4 core to replace the 3 core.
There are still electricians that think you can't use a green and yellow core within a flex as a live/neutral conductor? And they are just veryifyng, its not a departure if used as one.
for instance incase someone puts a nail through it
and what guarantee is there than the nail hit will operate the circuit device ?
absolutely none.
you can hit the live and nothing else with a twin & earth cable and nothing will trip.
there is no requirement for a cable to contain a cpc just for the sake of protecting the cable.
that is only achieved with swa & pyro , hence the relaxation of rcd protection.
amp david I did not think it there for that reason but did think it part of the reason (Biff now know after 20 years my mistake ha ha) so I could run 2 core cable and a separate earth if I felt so inclined
Reply to NICEIC’s Connection magazine (using CPC as a live conductor)? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
It's no good thinking they need to be sure. Simple continuity tests will verify any breaks.
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
