No continuity on cooker circuit. | Page 2 | on ElectriciansForums
Discuss No continuity on cooker circuit. in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
London
Not getting a continuity reading on the cooker circuit. I'm doing I.r. test and its low between l. N. Any ideas what the issue could be.
The cooker sockets is working also.
Are you linking out at the CU and then testing at the cooker isolator or the connector plate lower down? Make sure you are breaking it down correctly. Test just the feed cable (unless that's what your having issues with...) then just the cable from the switch to the connector plate. This will rule out bad connections.
If you are testing with the switch inline and it's not been used before (brand new) make sure you rule out a faulty accessory
Tell the client the have a fault. They need to get fixed. I'm just doing the eicr. I'm rubbish at fault finding mate.
Ah sorry. You've got a trainee badge on your status so assumed you were still learning. Obviously wouldn't be doing EICRs if you were. Be worth getting the mods to remove that if that's the case.
Fear not it does get easier.
If it's an EICR I'd probably have started with a Zs test using the socket on the cooker plate. In under a minute you'd know you have a CPC issue, either broken or termination issue.
The only way to get better is experience. People can teach you fault finding methods but the best way to learn is being left to it and sorting it out for yourself.
Simple one point radial circuits assuming that is what it is are straightforward to fault find and once you achieve this it will give you insight to something more complex, but complex or not fault finding methods are generally the same.
I'm rubbish at fault finding mate, suppose improve with experience.
Reply to No continuity on cooker circuit. in the UK Electrical Forum area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
TerryBNZ
T
