No continuity on cooker circuit. | Page 3 | on ElectriciansForums
Discuss No continuity on cooker circuit. in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
London
Not getting a continuity reading on the cooker circuit. I'm doing I.r. test and its low between l. N. Any ideas what the issue could be.
The cooker sockets is working also.
You need to visualise the circuit and a drawing helps. With the type of circuit you have this is straightforward if I remember tomorrow I will do some rubbish? drawings.
Westy is spot on here. Draw the circuit. Work out why you get the readings you get. It's not difficult- don't over think it.
Its just a cooker circut , pal, im thinking the earth cable is damaged.
You need to prove this so draw three lines, line, neutral and cpc. Leave the cpc with a gap in it and decide how continuity tests will prove the cpc is broken. You have a continuity tester and a lead with croc clips either end.
Reply to No continuity on cooker circuit. in the UK Electrical Forum area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
TerryBNZ
T
