no earth | Page 12 | on ElectriciansForums
Discuss no earth in the UK Electrical Forum area at ElectriciansForums.net
sima24
Hi, been to look at a rewire today and no earth connection at all. Tried to contact supply company to enquire weather the property is connected to a pme system but no joy after holding most the afternoon. I presume supply company doesnt have to supply an earth but just wondering if they would upgrade to pme or not? Or possibly it is a pme system but earth has been disconnected at some point (no sign of pme label tho) any views appreciated. Thanks.
Does that mean you didn't install an earth pit then?? If so what have you used to protect the cable connection to the rod??
I saw one with half a bucket of cement tipped over it once.
There it was, in a corner of a backyard, a pile of hardened cement with a length of 6mm green/yellow protruding from it & running through a hole in the back wall of the house.
What do you mean by a green box?? It's the actual cable to rod connection that needs ''long time'' protection.
One of these green boxes that say "safety electrical connection" on. Bearing in mind the distance from the rod to the wall is less than 30cm the probability of damage is minimal.
[ElectriciansForums.net] no earth
You'll be lucky if you get 2 to 4 years from that load of crap!! They should ban those bloody things, they stand absolutely no chance of lasting the lifetime of the TT installation!! Which is minimum of 30 years, but in reality much longer... Do yourself a favour and throw that thing away and get a proven propriety flush to ground, concrete or heavy duty plastic earth pit!!
So you drove your rod in the worst area possible on a domestic, straight into all that old builders rubble, ...that was clever!! lol!! If you had gone a metre or so, away from the house walls, you would have probably got a better Ra value too...
It is in the same place as the old rod, and as my house was built in 1826 there is no rubble - it is thick clay soil which is giving me a reading of 44 ohms which should get better over time. If the new rod had given me a rubbish reading or encountered rubble (not likely as the original one didn't) then I would have tried further away, but it didn't so it would be totally pointless to go half way down the garden for no reason. When (eventually) I repave the path it will be treated to a proper concrete pit.
Reply to no earth in the UK Electrical Forum area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
