No earthing | on ElectriciansForums
Discuss No earthing in the UK Electrical Forum area at ElectriciansForums.net
Baker1988
Kingston Upon Hull
Hi every one how are you all on this fine bank holiday.
I have a friend of mine who has asked me to change a light fitting in his house it is a rather old house i went to see what he needed doing and when i got there i saw that he has no earthing on his lighting circuit ( infact he has none on any circuit and he has bronze plated swichs and sockets) the light he wants is a metal chandelier type light.
I said to him i will not change the light fixture as it has no earthing for the metal and he started offering me more money to get me to do it but i still said no and said to him he needs to get it rewired or a seperate eath put in but he is having none of it and has said he will get a fully qualified spark in to do the work as it must be ok not to have earth or it would have earth am i right in thinking a spark wont touch this as it is? and am i right to turn this down?
You understand the potential danger,you advised him correctly of that danger,he doesn't understand or care
If you fit it,you can become liable for any harm that may ensue
If he fits it,he has nothing but his own stupidity to blame
Walk
Your right in what your saying op I would not fit the light either, all you can do is advise but I'd be more concerned if the client has metal sockets and switches with no earth as it obivous the dangers that may arise
There's nothing wrong with no earth on the lighting circuits, it just needs all the switches, roses, and fittings changing to non metalic.
It could have had green wires that appeared to be an earth and were connected to the lead water main that's now MDPE.
I suspect the same customer would have said it's got green wires it must have an earth.
Hi the house is really old dont know exactly how old but at least a few houndred years old
I should of been a bit more clearer sorry i only checked the lighting circuits none of them had earthing thourgh out the full circuit i did not check the sockets but yes all the switchs and sockets are metallic and also has class 1 light fixture.
There was no way i was going to do it he has just baught the property it is really big it has out buildings and a stable he is not short of a few quid so he could easily afford a fully quilified spark to rewire the full property he is just greedy that is all thats why he asked me instead.
I told him to get it fully rewired as he has a little kid about 3yrs old running round And he wouldnt feel to good if his son got hurt due to his greedyness
Reply to No earthing in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
2 3
