No main earth in domestic supply
P
P&Q
Hi everyone,
I got called in by a customer to install a new circuit for their cooker in the kitchen. So I went over and looked at the main supply and there was no earth. So I told them to get in touch with their supplier and ask about this missing main incoming earth cable and what is the Earthing system, and this afternoon he got back to me, and Scottish Power had simply said, some houses have earth and some really old ones don't - all they have is a Phase and a Neutral cable, and that's it and they're not gonna do anything about it.
I was just wondering, what the deal is with is, should I get back to them myself, or even set up a TT system myself?
Appreciate any advice in advanced guys
i knew this statement would shock people, its an option if you dont want to wait around for there 3 houyr response time! sorry guys ill take it back, but somethimes you mite not have 3 hours!
Try illegal!!!!!
Not bad practice.
With regards to fires' last post
Yep, if it's designed as a TT and you TNCS it, there are not generally enough DNO PME electrodes to raise the ground to the same potential as the MET. :cool:
net result = all extraneous conductive parts at 230v
So not only illegal but very dangerous (as eng54 correctly pointed out)
and thats as many abbreviations as I can squeeze into one sentence!
Yep, if it's designed as a TNS and you TNCS it, there are not generally enough DNO PME electrodes to raise the ground to the same potential as the MET. :cool:
You could have sqeezed in CNE after PME! :)
But I do agree with you Benny, very dangerous (and stupid) thing to attempt.
P&Q,
Engineer54,
