no resistance end to end on L & N | Page 3 | on ElectriciansForums
Discuss no resistance end to end on L & N in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This may come as a silly question but you did IR test the circuit first before any CR tests?
i had this with my fluke 1651 i kept getting 0.00 ohms on my end to end test, i was in the middle of my NICEIC visit, the inspector told me to take the batterys out of the meter and wait for 10 seconds then pop them back in.... you wouldn't believe it until you saw it... nulled my leads then did the measurement again and it was 0.31... has happened sinse on a 1653 and the trick worked.... (sounds like BS but true)
Reply to no resistance end to end on L & N in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
TerryBNZ
T
