View the thread, titled "NO +ve at switch!" which is posted in Australia on Electricians Forums.
Call out by landlord to house, down stairs bedroom light pendants damaged:
Pendants replaced however no live at roses or switch
Lighting circuit:
1Gang 2 way dimmer: 1 cable 1mm T&E
2 Ceiling roses : 1 cable 1mm T&E at each rose
Continuity of Neutrals to both roses ok
Continuity of switch wire to both roses ok
Wiring method: joint box / choc box
Above the bedroom is a bathroom
The T&E has been plastered in!
What would you do to get a supply to the switch with out lifting up the bathroom floor,
I would not be running a new live to the switch I would want to find the fault and trace the joint box or where ever the supply to the switch comes from IMO!
I am affraid you will have to knock a hole or two in the ceiling to locate the fault.
Blue to Bits make a good comment re this.
Best of luck!
Reply to the thread, titled "NO +ve at switch!" which is posted in Australia on Electricians Forums.
