raustin
Have a CU to swap so thought we'd go down the route of getting the DNO out to fit an isolator. Now wish we hadn't. The DNO is EDF and they will come out to disconnect the supply only. We will have to fit the isolator.
The issue is, that worst case we have a 4 hour slot between being disconnected and reconnected. So not long enough to risk swapping the CU as they won't reconnect if not safe. Fair do's, but they still want a full certificate for the installation saying its safe before they will reconnected even though the installation isn't being touched, just the isolator fitted.
Has anyone else come accross this?
