Noisy,buzzing contractor | Page 3 | on ElectriciansForums
Discuss Noisy,buzzing contractor in the Commercial Electrical Advice area at ElectriciansForums.net
Chattering contactors, many time in my time it was down to dirty pole faces on the magnetic part of the contactors , worth checking for grease and poor alignment on the magnetic side of things.
If it's brand new and chattering, check coil voltage and actual voltage being supplied.
It may be fault in retaining circuit.
Turn off DB and recheck for buzzing.
Turn off all circuits in DB.
Re-engage DB and introduce circuits one at a time.
Reply to Noisy,buzzing contractor in the Commercial Electrical Advice area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
