Non combustible cable supports in escape routes. | Page 2 | on ElectriciansForums
Discuss Non combustible cable supports in escape routes. in the UK Electrical Forum area at ElectriciansForums.net
dlt27
Hi all, I have just read a report by BRE on the effects on cable supports caused from fire. It stated the obvious about the plastic clips, plastic conduit etc failing. However what I found interesting was that the metal supports failed due to the plastic rawl plugs failing. So I just wondered what is the point of using non combustible supports if the rawl plugs fail. ( in concrete that is). Does this mean we should be fixing saddles up with those concrete screws rather than plastic rawl plugs!
I'd imagine it's not the raw plugs getting hot directly from the fire, it's the heat transferred through the bracket and the screws. If the rawplugs are polyethylene they'll melt at maybe 120-140 Celsius so I'd imagine it could be an issue. Maybe drop-in threaded anchors and thread rods would be better.
Reply to Non combustible cable supports in escape routes. in the UK Electrical Forum area at ElectriciansForums.net
I don't think anyone on here is going to say it needs replacing, some may even argue that it's not even a c3.
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
