Discuss Non continuous main bonding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i'll concede that, murduch, but i'd still make a note "improvement recommended".
Thanks for the responses guys - had a bit of a debate about this and hence the question. I agree Telex/Archy about the "crimp it, sorted", but as that's not always possible, I was keen to have the views of others on code or not, and if code, what.
as long as the main bonding conductor is continuous to the rod........ :ihih:
and i'll admit defeat . should have looked it up before engaging fingers.
Its not about win or loose, its about making sure we use the regs in the correct manner......
Reply to Non continuous main bonding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
