Nuisance tripping of kitchen lights | Page 2 | on ElectriciansForums
Discuss Nuisance tripping of kitchen lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If after doing the necessary testing you find no fault, I suspect the problem to be a high in-rush current when the switch is first made. LED lamps and their drivers do have high but short duration in rush currents and in your case you turn on 4 at the same time.
You could fit one of these:
http://www.cooper-ls.com/sites/coop...eets/cooper-ls-datasheet-inrush-limiter_0.pdf
an inrush current limiter with a rating of 16A.
see also:
ESB AC Inrush Current Limiter 3,6kW ... 48kW CAMTEC Power Supplies - http://www.camtec-powersupplies.com/inrushcurrentprotection_esb.html
PS: Or change LV Luminaires for Mains ones if that is a cheaper solution. In our new kitchen we have 16 Saxby 7W Mains GU10s supplied by a 6A type B mcb all switched on together.
Given the OP has stated he can't access the transformers, this change over could be tricky!
Don't fret - by reading your advice and acting on it folk will be learning from standing on the shoulders of a giant.
'If I have seen further it is by standing on ye sholders of Giants.' Issac Newton(apple watcher) in a letter to Robert Hooke (of elastic springs and microscope fame).
Reply to Nuisance tripping of kitchen lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
