Leesparkykent
Nearly Esteemed
Any one know a supplier of these? looking for 25mm and 20mm as have a few new builds that are all metal portioning...Fed up of using grommets. cheers
Discuss Nylon snap in bush in the Electrical Tools and Products area at ElectriciansForums.net
RS did do them but only in different size kitsAny one know a supplier of these? looking for 25mm and 20mm as have a few new builds that are all metal portioning...Fed up of using grommets. cheers
Spot on cheersEbay 272074080976 or 272102915588
Normally use a holesaw but the Armeg acceler8 or starrett equivalent.Sdproducts do snap bushings, but a 20 mm hole is narrowed considerably. Out of interest do you use a punch to make holes, or holesaw I've been looking for a plier like tool as the metal is so thin a holesaw makes a poor opening.
I always use a stepping drill.holesaw
Always use an automatic punch for locating with no skid haven't really tried Starret holesaw. But the stepping drill has the advantage of a really smooth deburred hole on plastic as well as metal. But the bit about the apprentice.... yeh I can see that.skid about
Reply to Nylon snap in bush in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
