diabalo
Hi I was hoping someone could shed light on the wiring of the timer in my daughter's maisonette? I found a wiring diagram of a teleswitch but I can't locate a diagram of this clock which I believe is by Horstman. I understand the liveView attachment 12522
in on the left and the switched live out on the right going to the second, off peak, Henley block, and also the neutral feed to the clock, and the signal wire to the meter. I am puzzled by the live feed to the clock which appears to come from the second, Henley block. Surely this feed is only live when the timer is in the off peak period. I did wonder if the clock took its feed internally from the incoming live before the switch and if the thin wire is actually an output from another switch as in a water heater feed but that seemed unlikely as it goes to the live side of the second Henley block, not directly to one of the three off peak fuseways. I should say that there are no off peak loads any more. The fuseways are still there but all the outgoing cables are gone.
Many thanks in advance.
Rob
Rob
