Oh go on then! So it's not the neatest you'll see but I always struggle a bit with neatness with board changes, especially when there are cables coming in from all angles! I am aware that the hole at the back is too large (as pointed out by Paul on a picture I posted before) but have only knocked out what I needed (parden the pun) since I received the feedback! We were altering the existing installation (half renovation type job) adding sockets and and some lights, we were also asked by the client to change the board. The change was fairly straight forward; none of the circuits needed lengthened and everything tested as it should. All simple stuff. A brief list of what I did:
1. Turned the radio on!
2. Prepped new board
3. Identified unmarked circuits (2 of)
4. Isolated board
5. Perfomed IR test
6. Marked up cables
7. "Unwired" board
8. Removed old board & mounted new one
9. Terminated circuits, performing ring tests as RFCs were terminated
10. Performed R1+R2 tests on all relevant circuits
11. Energised board
12. Finished testing including Ze, PFC, Zs's and RCD tests
13. Marked up and stickered new board
Job done!
Before:
After:
Managed to avoid top entry (unlike previous spark) so hopefully maintaned some IP rating!
Big thanks to you guys again, these comps are excellent!
4. Isolated board
5. Perfomed IR test
6. Marked up cables
7. "Unwired" board
11. Energised board
Job done!
Before:
![3f747f41d9b317cdcb752d64a7534e73.jpg](/proxy.php?image=http%3A%2F%2Ftapatalk.imageshack.com%2Fv2%2F15%2F01%2F15%2F3f747f41d9b317cdcb752d64a7534e73.jpg&hash=5587b25a6013e3c9f611380227b3b66e)
After:
![583d962b3dcc74dc0c42502a06f7d2d3.jpg](/proxy.php?image=http%3A%2F%2Ftapatalk.imageshack.com%2Fv2%2F15%2F01%2F15%2F583d962b3dcc74dc0c42502a06f7d2d3.jpg&hash=ebb7c3f59dd31aa99dac2f4d47ce04f9)
