old pyro | on ElectriciansForums
Discuss old pyro in the Talk Electrician area at ElectriciansForums.net
uk
whats the best size metric equivalent for an old lighting pyro?
3l1.5 is slightly too loose 2l 1.5 is too tight.
would re tapping the pots to a slightly bigger size work or a solder ring at the top?
any tips would be appreciated
Pyrotenax did publish a chart of imperial cable sizes with their metric size equivalent, current capacity and metric fittings sizes. Have a search around the forum and you should find it somewhere I'm sure.
Some cable/pot combinations do have to be soldered while others need the sheath fettling with a bit of emery.
owned by pentair now if that helps.
(bicc was sold to tyco and pirreli and tyco was bought/sold to pentair)
errrm, can I do what now? i'm an electrician not a bleedin computer geek ;)
or in other words you're lucky I managed to get it posted by any method!
Reply to old pyro in the Talk Electrician area at ElectriciansForums.net
Hi and Welcome to the forum! Sounds like you keep yourself busy in your retirement!
