old style wireable CU | Page 3 | on ElectriciansForums
Discuss old style wireable CU in the UK Electrical Forum area at ElectriciansForums.net
N
nmginn
Im newly qualified but haven’t come across a house wiring as old as this one and would appreciate any advice you can throw my way,
House is approx. 80 years old and still has original CU fitted, couple (friends) don’t want to start thinking about rewire etc at their stage of life, but my main concern is to make the outside wiring attached safer than I think it is at the moment.
Old style CU with wireable fuse carriers, all carriers are labelled 5 amp but have different fuse wire used depending on circuit. Reason for this was they haven’t changed the carriers in all the years they have lived there and all socket circuits initially ran from 5 amp fuses, they found problems when they started using more modern electric heaters etc years back. thankfully has the savvy to remember to use appropriate fuse wire rather than just fitting 5 amp like the carrier suggests.
Radial Circuit to garage
2.5 cable although in 5amp carrier has 15amp fuse wire used and runs as a radial to firstly a double socket upstairs and then from there runs outside to garage. Approx. 30ft run of cable.
Circuit goes to a very old style wireable fuse carrier with 15 amp fuse wire, from there 2.5mm cable runs to a junction box where 2.5mm is again connected and runs off as another radial to two double sockets. From same junc box 1.5mm cable is also used to run off to two internal lights and a further 3 outside security lights.
So as it stands they have a lighting circuit and a socket circuit attached on same circuit from main CU with an inline 15 amp fuse carrier box and then also protected by a 15 amp in main CU.
My initial idea was to at least install a new garage CU with a 6amp MCB for lighting circuit and a 16amp MCB for the sockets but doubting that now.
yes the outside fuse is lower rating rather than higher thankfully but they are looking at buying a freezer and possible tumble dryer to use in garage and I have concerns that current circuit will cope.
Any advice please would be appreciated
it wouldnt take much to damage a swa and u dont know by who (kids stabbing or trying to cut it). its what i prefer to do u can follow the regs and no more if you want.
So you would advocate always protecting a buried SWA with an RCD? Daz
- - - Updated - - -
any way i finish at 3 so till monday see u laters suckers hahaha
I still say you are way younger than you claim. :devilish: Daz
Thats the beauty about this game. If you think the situation warrants it you do it, if you dont you dont -- unless its an implicit regulation requirement!. No right or wrong to it as its your 'professional' opinion as to what is required based on what you see the situation as ...... or something around those words!
After reading the initial OP my advice would be to confirm the age of the installation and be 100% about that, as E54 rightly pointed out the installation in parts could be 60 years old due to the consumer unit, I suspect it is all ages as Modifications must have taken place over the years, if it is indeed over 40 years then I would recommend a full rewire to the customer at that age, any less and yes I would suggest a EICR. MIke
Barsteward! I'm going to have to have a go at Biff.
May as well resign now.
Trouble is for me buddy, is the fact I cannot spend time playing the game, yes I could play tonight and probably play for an hour, but it could be Tuesday before I could move again, hence the 3 day game you get bored with and to be fair rightly so. I have a complicated Life, a lot of Bullsh&t, and to add, time away from reality for periods of long time, this is why I canny play any quicker and often lose interest LOL. I Blame Builders and architects for all my troubles and my lack of skill playing chess haha
This is referring back to the opening post
quote
Please explain/expand on what you mean by that statement
quote
Good point - I never read that one properly. Is he saying 'someone savvy' changed the 5A fuse wire for 15A fuse wire because it kept blowing ???? The mind boggles !! Daz
Reply to old style wireable CU in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
