one cert or two? | on ElectriciansForums
Discuss one cert or two? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
craig1000
If an install you work on has two CU's, should you issue a EIC for each or one EIC & two lots of DB
schedule of results sheets?
Reply to one cert or two? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Because of the addition of separate columns for RCD type etc. I use Easycert software which gives the option of fitting it all onto one page.
loz2754
L
Thanks for that, good line of thought. My take is that safety is about protection of life/people/livestock hence the earth thing and protection of...
