M
mcfhoopy
Hi
I have just used a basic socket tester on one of my double electric sockets and it is reporting ‘Open Ground’
Other sockets are reporting correct
Any advice?
is likely to be dangerous, if a faulty device is plugged in to it, then the protective devices that keep you from being less alive than you are now may not work correctly and save you.
get it checked by an electrician ASAP and don't use it until it has been repaired.
All sorted thanks - earth wire wasn’t connected to the socket. Probably hadn’t been for years ……..
Open Ground
UK
mcfhoopy,
mcfhoopy2,
