Opinion on Supply System Type Wanted: TN-S or TN-C-S | Page 3 | on ElectriciansForums
Discuss Opinion on Supply System Type Wanted: TN-S or TN-C-S in the The Welcome Forum area at ElectriciansForums.net
Yes TN-S
As you say your test results of pssc and pefc are what they are.
I would go for TN-C-S.
If you look carefully at incoming supply, the concentric cable has only 2 conductors. The centre line conductor and outer stranded neutral. Part of the stranded neutral has been seperated and used to feed the earth terminal. (Effectively creating a link between them) the remaining strands have then been painted black to form the neutral conductor.
So to my eyesight, which is not what it was, it's combined in the service head, therefore TN-C-S.
Time to go to spec savers I think, there are clearly three separate conductors there!
Oh, I was thinking more like this :tearsofjoy::tearsofjoy:
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Opinion on Supply System Type Wanted: TN-S or TN-C-S in the The Welcome Forum area at ElectriciansForums.net
A bit like saying plumbers makes good electricians. 🥴
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
