Outside lighting | Page 2 | on ElectriciansForums
Discuss Outside lighting in the UK Electrical Forum area at ElectriciansForums.net
steveo_10
Hi I have been asked to wire up an outside light for some one I am not sure If i can wire it up to a light switch do they can have it on when they want if so what cable and if it has to be connected to an rcd
Any advice would be appreciated cheers
I thought these forums were ment to help and advise people that need it clearly I as wrong again bunch of ****s
Sorry you have had a rough experience. This site IS NOT for step by step instructions. Even if I gave you them you could, for example, leave a terminal loose and burn the house down, as I have given the instructions I could get sued.
You want advice... read the manufacturers instructions. If you still dont know you need to get an electrician in.
As Kate says and even if you manage to get your light up and running are you confident enough to test the circuit after to ensure it's safe mate ??
Sorry if i seemed out of order but it is just my banter. No offence intended
Reply to Outside lighting in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
Yes agreed this is definitely out of my comfort zone and it was from the start. Connecting the lights on to scaffold just had me on edge. So the...
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
