View the thread, titled "outside lights - up lighting trees" which is posted in UK Electrical Forum on Electricians Forums.
B
brman
got a job to put in some outside lights and it turns out the guy wants a couple of lights lighting some trees from below. He is after soft lighting so I was thinking some diffused CFL spots but I've never done ground mounted lights before.
Is IP44 good enough or do I need to go higher for ground mounted stuff? Are there specific mechanical requirements for ground lighting?
What about cabling? I was already planning SWA underground from the house but was originally planning flex (NYY-J?) from that to the lights. Now I am not sure the best way of cabling to the ground mounted lights as I guess flex is likely to be damaged. swa all the way? it could be a pain to get underground to where he wants the lights because of tree roots......
sometimes not with pulg inserted they arent need to watch what your buying
Hmm... I should stop asking questions on forums, I only get worried by the answers ;)
I've used masterseal before and not had any problems but I was going to try the masterplug ones, if only because they are remarkably cheap! I can find limited info but they look like they seal with the plug in place. Anyone know any different?
There are many many plug/socket combos out there which remain weatherproof without costing the earth. If you are really concerned then go for an IP68 pair which is the best you can get (short of putting the connector itself inside an enclosure).
Indeed. I wasn't concerned until mogga made his comment :(
I'll try the masterplug ones. I haven't used them before but they are IP66 rated so I would hope they are up to the job and they are half the price of the masterseal ones so it is worth getting some to have a look at at least.
I think mogga was referring to the fact that some sockets are waterproof until you plug something into them. As long as you get a plug/socket combo rated at IP66 then you will be fine.
Indeed. Masterseal quote the rating with a standard plug/cable but I can't find any info on the masterplug ones. At under 1/2 the price I am starting to doubt them but I have emailed masterplug to see what they say.
Thats why I made the comment Iv had clients say things like "iv seen waterproof sockets at --- for a fiver" only for me to show them said waterproof socket with plug in and flap open Iv got one masterseal on each shed Only as they came off a stripout done a couple of years ago NO chance would I purchase them myself there is one BnQ do as outside"KIT" that seals with plug in theres even room for a smallis adaptor type plug I think they are masterplug ones
the new masterseal ones have made the clip to hold closed easier to work and bigger space for moulded plug tops
Ok. Thanks for the warning.
Reply to the thread, titled "outside lights - up lighting trees" which is posted in UK Electrical Forum on Electricians Forums.
