Outside socket earthing | Page 2 | on ElectriciansForums
Discuss Outside socket earthing in the UK Electrical Forum area at ElectriciansForums.net
jmmrly
UK
Hi,
I'm located in the UK and replacing my outside double socket plugs with ener-j smart wifi sockets. I've wired it as the picture below, exactly the same as the old one. I used my tester and it's only earthing one plug. There's another earth socket but I didn't need an earth wire in each one in the old socket. I've googled and it looks like most plugs only need earth in one socket, and it connects to the other. I guess this doesn't connect the earths. So do I need to buy some earth wire cover, split the wires (there's two wires in each) and plug one earth wire into the other plug?
Seems silly but thought i'd ask in-case i'm doing something stupid.
[ElectriciansForums.net] Outside socket earthing
If I recall correctly, the BG external sockets are basically a housing with a standard BG socket installed in anyway, so you might be able to get one of those and straight swap the socket for the one you linked.
Just to point out definitely don't split your existing earth wires and put one in each. You'll end up losing earth throughout the circuit if they're not interconnected through the socket. As others have mentioned these sound like they're non compliant.
The new socket I bought has them connected, I've only put it in one. I got rid of the iffy one from the OP.
Reply to Outside socket earthing in the UK Electrical Forum area at ElectriciansForums.net
2 3
IP68 sockets are similar to IP67, they just take a few days longer for the water to fill them up....
