M
MJS9691
We have a new ceramic hob (6kW) factory prewired in 2.5mm flex and oven (2.6kW) prewired in 1.5mm. After diversity calcs the existing supply 32A protected 6mm (9m run) suggest a more than adequate supply for both appliances however:-
Some electricians are suggesting further protection of the flex beyond the outlet plate to protect the individual cabling on the appliances with FCUs and some say its OK to wire directly into a dual outlet plate with no further protection. Some Electricians are even suggesting removing the factory fitted cables and replacing with 6mm right up to the appliance.
Is there any definitive rules on this, or is this purely down to the electricians choice i.e. is it necessary or not to protect the 1.5mm flex cabling in the event of a fault on the appliance and it somehow drawing more current than the cable can take. There is no information on appliance fusing or protection in the installation manuals of either appliance.
Views on this matter would be appreciated as it still appears to be a grey area reading through the posts with installations not standardised...
Many thanks
Many thanks
