Customer wants to plug his new oven into the kitchen ring i said that it still needed to be on its own supply even though its on a plug. What do you all thinl ?
Cheers
Cheers
Discuss oven on a plug top in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any cooking appliance rated at 2kW and above should have its own dedicated radial from the CU to prevent the RFC from being loaded for long periods.
However, if a new radial is not possible then it may be plugged into the ring, but i would say, only if its a dedicated kitchen RFC.
Out of interest .... no dissent ... but (and there's always a but ) .....
If an appliance comes with a lead ending in a moulded plug, I just make the assumption that it van only be 13 amps rating simply because it's a 13 amp plug .....
So, even if it's a cooker, with a plug on the end it doesn't need a dedicated circuit. Am I wrong?
Read my previous post, carefully.
I did but as I have no idea what an RFC is I didn't include it in my thinking. Now go ahead and tell me what it means ..... and I'll shall have the load lightened
Reply to oven on a plug top in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
