Oven thermostat & temperature | Page 2 | on ElectriciansForums
Discuss Oven thermostat & temperature in the UK Electrical Forum area at ElectriciansForums.net
macblack
Merseyside
Hi, looking for some advice.
The wife recently said the oven doesn't cook food the same way it used to (recently a chicken pie came out cold in the middle). So I bought a oven thermometer, put the oven on 200c and after about 7 minutes the light went out. I checked the oven thermometer but it was only reading about 140c.
I assumed it was a faulty thermostat, so I bought and fitted a new one.
I repeated the test and got exactly the same results.
I borrowed an infra red thermometer from a friend and again repeated the test. The oven thermometer was still reading 140c. Interestingly the infra red thermometer said the back of the oven was 200c but when I pointed it at the oven thermometer it had a reading of 140c!
Its a fan oven so I assumed an equal temperature all around. If you leave the oven thermometer for 25-30mins it does eventually get to 200c.
So I'm a little confused and would appreciate any insight.
Thanks in advance.
Mac
Reply to Oven thermostat & temperature in the UK Electrical Forum area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
