Part F building regs................... | Page 3 | on ElectriciansForums
Discuss Part F building regs................... in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Had an email from some outfit suggesying to keep building control happy we sparks should do a course to certify our extractor fans, cooker hoods etc.. never been asked for one yet but maybe one day i will. If i recall in the niceic online portal there is a form dv1 for certificating such things.
Anybody heard of this lot (email below)
Building Inspectors are tightening up on Part F of the building regs. Ventilation is becoming a hot topic right now, and electricians are bearing the brunt of it. If you haven’t alreadybeen asked for a fan test certificate for your bathroom extractor fan or cooker hood install, you soon will be!
The good news is that doing your own fan tests isn’t that complicated - once you know how! Our online course will get you quickly up to speed on testing domestic extraction fans - plus we’ll even give you a FREE HIRE of the test equipmentyou’ll need to do it!
With our easy-to-follow videos and checklists, you’ll be confidently testing your installations and providing professional fan-test certificates for your clients and Building Inspectors. And since the average price paid for a fan test done is over £72, you can charge for it too!
PEATA is the Professional Extraction Airflow Testers Alliance.Join us today, and for less than £6.70 per month you’ll get comprehensive training, easy-to-use online certificate creation, a FREE HIRE of the test equipment, and more. It’s a no-brainer!
https://www.peata.org.uk/
Sounds like for around 75 quid a year you can have another van sticker!!
Hello All,
I can see from the above messages that the responders to this thread are likely to know far more about this subject than me but I have been aware since about 2009 / 2010 that `Building Regulation Part F - Ventilation` requires some `Ventilation` work to be carried out by either a `Competent Person`- a Member of a Competent Persons Scheme [one of which was being run by CORGI at about that time] or direct Notification to the Local Authority Building Control who I am sure would be looking for `Design & Testing` details on all but the most basic Ventilation systems.
Although CORGI no longer run the Gas Register they do run Competent Persons Schemes - `Ventilation` amongst them - and I am guessing that they will have `Training providers` offering Ventilation Courses - from memory a person having taken a `Ventilation` Training Course can call themselves a `Ventilation Technician`.
Competent Persons who are registered on such a Scheme and carry out Ventilation work that falls into the category that has to be Notified to the Local Authority Building Control [does anyone know what is ?] can notify via the Scheme providers in a similar way that Gas Safe Registered Engineers notify via Gas Safe.
And I assume similar to how Electricians notify under `Part P` via whatever Scheme provider you belong to.
I remember thinking at the time [2009 / 2010] does this apply to Kitchen and Bathroom Ventilation Fans / Cooker Hoods ?
I did not have any motive to further investigate exactly what is involved in the Ventilation Training or exactly what `Ventilation` work is required to be Tested.
I have not installed any Open Flue Boilers since then that required Mechanical Ventilation to be provided - that would require the Intake Fan to be electrically linked to the Boiler operation so that in the event of a Fan failure the Boiler could not operate - also depending on the `Air Tightness` requirement of the Building such a Fan would obviously have an effect on that.
I would expect that this form of `Ventilation` work would be subject to `Design & Testing` by a Ventilation Expert and be subject to Notification to the LABC.
As the subject of a `Ventilation Competent Persons Scheme` may come up as required for some Electricians perhaps a Member will investigate further and post some information on the Forum.
Chris
Reply to Part F building regs................... in the UK Electrical Forum area at ElectriciansForums.net
The tighter rules came in around June 2022. I think you summed it up nicely. My understanding is that a competent electrician could install...
