Part P assessment question | Page 5 | on ElectriciansForums
Discuss Part P assessment question in the UK Electrical Forum area at ElectriciansForums.net
Wales
One of the questions on a recent Part P assessment was how would I wire an external outbuilding if the earthing arrangement to the property was PME.
I said I would run a three core SWA from the property to the outbuilding and use the cable armour and the third core as the exported CPC.
I was highly criticised and was told that I should install a rod at the property and at the outbuilding.
I can find no mention of this in 17th ed AMD3 book, can anyone tell me where i would find this if it is the case.
I have had a couple of other Assessments previously where they have checked out building installs and never mentioned this so I am not happy.
On a 30ma RCD ? :)
Hi Dave - the fault I'm thinking of is loss of N on the DNO side of the cut out. So with TNCS the local N and E are still connected, but floating now. Initially the kettle will not carry any current, as N is dis. But when it's earthed metal casing is touched by me, I provide a path for current flow. This current travels via L and N and the element (so the RCD is still happy) and back to cutout, onto installation E and circuit cpc back to the kettle and me ... Ugh.
If there is bonding in place to metallic services (not plastic) current will still flow through the kettle.
Reason for the proposed requirement for consumer earth electrodes, is because of the increase in plastic services.
Reply to Part P assessment question in the UK Electrical Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Testing and Inspecting if the right course is a very good qualification to have and if you are to become an electrician you will need a...
