Part P assessment question | Page 3 | on ElectriciansForums
Discuss Part P assessment question in the UK Electrical Forum area at ElectriciansForums.net
Wales
One of the questions on a recent Part P assessment was how would I wire an external outbuilding if the earthing arrangement to the property was PME.
I said I would run a three core SWA from the property to the outbuilding and use the cable armour and the third core as the exported CPC.
I was highly criticised and was told that I should install a rod at the property and at the outbuilding.
I can find no mention of this in 17th ed AMD3 book, can anyone tell me where i would find this if it is the case.
I have had a couple of other Assessments previously where they have checked out building installs and never mentioned this so I am not happy.
Worst assessment I ever had was with a stromer assessor, he couldn't stop telling me how good he was and then giving me incorrect information including that if an outbuilding in a garden was more than 10 metres from the house it had to have TT.
I got fed up with constantly having to chase stroma for every certificate I applied for (I complained to the stroma manager over the phone and in emails and nothing changed). The ÂŁ4 extra a week I pay to the NICEIC is worth it to me.
That sounds like the Stroma assessor I had last year. He insisted that any outbuilding FURTHER than twenty metres from the main building needed to be TT.
is this the assessor?
[ElectriciansForums.net] Part P assessment question
To my mind it seems everybody is wrong
Firstly the assessor for calling it a non compliance of the wiring regs
Its wrong by the op (and everybody else here) for assuming this is a issue about those wiring reg being contravened or not
As far as I understand,there can be dangerous situations created by incorrect use of the supply earthing arrangement
Its a "suppliers" stipulation that Pme not be used outside of the equipotential zone without their permission
That permission should be sought from the supplier in order to do so,otherwise its get yourself a rod and provide your own
The wiring regs will tell you how to cater with whatever earthing is used,it does not give choices of what to do with the earthing provided by others and whether it should or should not be utilised
If thats the case then the DNO should be providing that info when they install the supply or a upto date map online so the information can be cross referenced.
Reply to Part P assessment question in the UK Electrical Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Testing and Inspecting if the right course is a very good qualification to have and if you are to become an electrician you will need a...
