Hello guys
my seaward PAT tester has given up the ghost, i have some small PAT jobs coming up and was thinking short term of being able to just use my multi function meter.
R2 test on class 1 equipment using low voltage ohm meter
Insulation resistance testing with leads
Trying to think what other limitations i have by just using my multi function test instrument?
I'm not certain what the current PAT testing consists of,but if the tests are possible using a calibrated MFT,i would assume it was OK.
There are earth continuity,polarity and IR tests,so an MFT would cover these. It is not a statutory requirement,so as long as any certification you provide,matches the testing you have done,all is well.
I was told.a long time ago,that you could offer PAT testing,as a purely visual only examination,providing the certification,stated this. Obviously,this does not example due diligence,too thoroughly,but would be legal.
OP - do the items you are checking actually need any testing? Most small appliances these days are class II and may only need inspection. Remember, the phrase 'PAT Testing' is misleading.
Also bear in mind the HSE guidance on the inspection/testing of equipment in low risk environments - there is a document available.
A lot of people are surprised about how little actual testing is needed.
As Westward 10 saysyou will miss the high current earth bond test, you will spend ages pratting about trying to get good continuity.
There are frequently Seaward Supernova Plus's for sale on ebay for ridiculous money, I bought another the other day for £25.22 delivered. Cracking tester if a bit chunky
Many handheld PAT testers only produce 200mA “Soft” earth bond current. BTW, Portable Appliance Tester refers to the test meter being portable not the appliances ranging from handheld to fixed!
To be accurate, PAT is a non existent phrase. The correct terminology is ISITEE.
Portable is irrelevant as you say.
london
Business Name
Platinum electrical
PAT Tester broken but i can use megger?
chris day,
static zap,
