Pat testing issue | on ElectriciansForums
Discuss Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
dj2102
Eastbourne, UK
If I have a Class II equipment and someone cut the plug and replaced for a new plug with earth pin. Is it will be pass or fail.
Or you have to replace for lead set ?
Doesn't matter the new plug has an earth pin. Did the old one have a plastic earth pin and why was it replaced.
Can’t see a problem with that.
Lots of class 2 stuff has a plug with earth pin, normally with 2 core flex
For me if is the II class equipment and someone had a fault on the moulded plug. What should do replace the for new moulded plug with a cord like was before.
Because this will be comply with a definition of II class equipment
Look up the definition of class II equipment in the ISITEE code of practice. It does not preclude the use of a plug with a metal earth pin for class II equipment.
Reply to Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
often one or 2 screws are attached to some earthed metalwork inside, it is worth doing a quick continuity test to them.
