Pat testing issue | Page 2 | on ElectriciansForums
Discuss Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
The Neutral wired to the Earth pin may be a problem ...o_O
Only if there’s one of those pesky rcd things involved!!!
You've obviously made up your mind already, so not sure why you asked the question in the first place.
So the plug is not the part of the appliance???
Is your leg part of the body ???
Depends how you look at it, the appliance is tested for Class II requirements but the plug falls under different standards and is not a Class II part whether the appliance it connects is Class II or not.
Lets suppose your Class11 appliance had a moulded plug with a plastic earth pin, and unfortunately someone stood on the plug and the earth pin snapped off. It's going to be tricky plugging it in to some sockets. Do you throw the appliance away, or put on a new standard plug with an earth pin?
The latter, methinks.
The amount of broken off plastic earth pins I have had to tease out of a socket.
Reply to Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
often one or 2 screws are attached to some earthed metalwork inside, it is worth doing a quick continuity test to them.
