Pat testing issue | Page 3 | on ElectriciansForums
Discuss Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
this thread seems to be getting lost here.
A class 2 appliance is double insulated, therefore not requiring an earth.
it is still class 2 if there is an unused earth pin in the plug.
it is still class 2 if there is an earth in the cord set that is not used.
it only becomes class 1 when there is a metal surface that could become live under fault conditions therefore requiring an earth.
this is so simple I am amazed it has had over 30 posts.
some class 2 items have exposed metal components that are not earthed.
But I am thinking only about The class II appliance.
Your over thinking this, you have had plenty of replies fella, I assume you have had your answer, just not an issue
What is a "mobile appliance"?
The common types of equipment within the 4th Ed. CoP are, "portable", "movable", "hand held", "stationary" and "fixed"
And what is your appliance?
a truss judging by some of the posts.
Can you still get Bonios? I remember them from my childhood when we had a Golden Retriever, and I quite liked to nibble a Bonio...
Is your leg part of the body ???
Yes, but my body does not use protection class II as defined by IEC61140, and my legs are not made to BS1363. I don't have an earth lead either, so I must be class 0 or III. Can anybody read the label on my back to see if I'm SELV?
Anyway, it seems there are dodgy plugs in circulation that are rewirable but have a plastic earth pin (officially called an ISOD - insulated shutter-opening device). This configuration is not permitted by BS1363 even for class II applications. If the plug is rewirable it must have a metal earth pin.
Pic here: New Counterfeit Plug Type - https://www.pat-testing-training.net/articles/new-fake-plug.php
Reply to Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
what is the piece of equipment and part number?
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
