W
whazza22
Just after a bit of help with filling out the certificate for a Periodic Test and Inspection.
Using a Hospital as an example where you have alot of sub mains, feeding sub mains etc.
The sections im struggling on are:
Supply Characteristics and Earthing Arrangements + Main Switch or Circuit Breaker.
As its a sub main fed from another distribution board, which is also fed elsewhere, then where would you class the origin as?
Im assuming the Main switch would just be the isolator on the panel being tested and not the isolator/fuse which feeds that panel??
Where would I find details for Supply Protective Devices Characteristics?
