Periodic Testing
Maybe I'm being thick but can you translate that last line for an 'oldun ?
Edit Sorry,just seen the dyslexic disclaimer!....a re-phrase would be nice though!
Basically if a Electrician can just do a EICR, for a DIY doing their own work.
Dosnt that make all this 3rd Party Stuff usless and not even worth talking about.
Why dose the world turn?
Ok Well thats what the 3rd PARTY thing dose .. lets DIY change things like CU and then have someone else TEST them.
What the Goverment wanted. I am not here to debate such a thing.
Why me? i guess because I've passed my testing qualifications, and guessed they think i MIGHT be able to do that 3rd Party Stuff and then they can have someone sign it off..
Notify? well i guess they did as they expect me to do a EICR.
If its an older installation I would ask him when he's planning to do the job and switch you phone off on the day - a CU change, no testing, adding RCD's, IR issues, borrowed neutrals....
Best keep well out of it.
On the rare occasions I'm asked to do this, I simply say I do the work completely or I don't do it at all!
To my mind, the only way 3rd party certification can work, is if the 3rd party attends site during construction.
I don't see how else verification of cable depths, prescribed routes, etc. can be made?
The only other option would be to conduct a PIR.
Lets think of the 3rd Party in Par with the Locale Council, I am guessing they will have to be told, and i am guess they Wont come out and watch you do all of it, just come out before you put in the cables, talk to you were you are putting them in and depths etc, and then come back out when you are done and test the job.
But what i am asking, as he asked me to do, is a EICR Peroidic report.
BS 7161 does allow for the design, construction and testing of an installation to be carried out by separate individuals.
It even allows for people who are not actually involved in the design, construction and testing to sign off an EIC.
However those kind of situations are usually found on larger construction sites and with larger electrical companies, where there will be someone in overall command of the project.
To have a situation where a complete stranger turns up at an installation with no knowledge of the design, construction methods, or even the materials used, to issue an EIC, is to my mind a farce.
If you are asked to do an EICR on a property, you have no idea who installed it if there is no paperwork.
You just report on the installation as you find it.
If Johny DIY has done it and it shows, then it gets an unsatisfactory result.
If it checks out, it gets a satisfactory result.
It is just a report not a certificate.
Work done without notification is still illegal no matter how many condition reports it has :)
This 3rd part certification is a load of nonsense, it should be stopped. It is far too open to people getting bunged to make out they have done the work in this sort of scenario. The only way anyone can honestly say that an installation has been installed to the regulations is to be on site during almost all of the work, and as others have said who is going to do that when they could be doing the job? The only way it should be allowed is with bigger firms who have dedicated inspectors who are on site and keep a proper account of things. I know for a fact there is a guy round my way doing it who only ever goes on site when all the works done!
seem to turn a blind eye and not alowed to talk about such things.
when i was doing my testing courses, my tutor had one guy who did houses and had to do about 3 a day.
My tutor did his own house and took him all day to do a full test on it.
and i know my sisters house wasnt testing, as i found lose wires, and one socket wired wrong L-N crossed over.
i think im going to look at the test results i think the whole lot is fudge really.
Tutor also talked about how some people do VAN TESTS, were they just sit in the Van writing in Figures.
To OP, you don't know whose done what. Get in there, carry out a i&t, get your money and give them EICR. Job done
With respect that's not on is it? You have just said yourself you have no idea what is lurking behind the scenes, so only a fool would put his name to it. This is peoples safety we are talking about.
Are you telling me for PIR you carry out you know what's lurking behind the scenes. It's not a EIC its a EICR.
Thats the point, its an EICR on something that has never had an EIC, isn't it? If someone has done a CU change and added sockets etc, then a cert for that work should be issued, not an EICR? When you do an EICR you would like to think that the installation was actually certificated properly on day one, whenever that might have been?
In a perfect world yes that would be the case but tell me how many times when you asked for previous paper work they had in hand? I can count in one hand the times that happen to me. My experience anyway.
DuaneMHunt1976,
DuaneMHunt1976,
