Phasing nightmare | on ElectriciansForums
  • Thread starter Michael Smith
  • Start date
  • Replies 113
  • Views 9K
Discuss Phasing nightmare in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Michael Smith
I want to build a house thats mains-less (no need for the grid (but still attached for emergency needs)) but..... i have had a look around and they recommend that 3 phase systems are more stable than single phase and uk houses run single phase, but as i want to build a huge F in pool too, i need a 3 phase supply for that, which easy answer is.... get a single to 3 phase transformer...... but what can i do if my 'Mains' supply is 3 phase from a motor generator which WILL recirculate to power itself ;)
i need a system that will:
power at 230/240V 1PH 100A 200KW
BUT
Also 330/480V 3PH 100A 400KW
Possible????
the motor generator: 480V 3PH 200A 1000KW (200KW to power itself)
just a funny thought ---> maybe put a HUGE flywheel on the motor so i can hand crank it up ;)
Or Homework time for 11 year olds??
If the post is serious, the O.P needs Professional help in 2 areas.
Design and spec of the Electrical system and medical to be thinking they can generate their own stable supply cheaper than the grid can supply.
Make that 3 areas
Thinking you can put 200KW in to a motor/generator set and get 1000KW out and use 200KW of that to power itself has got to be in a class of its own!
if what you are saying is true then your making out that motor generators have no point
example:
1 unit (1KWH) is ÂŁ80p; if im using 2000KW then thatll be ÂŁ1600 per hr to run it...... the motor generator can use 1/5 of the power and produce the same output (ÂŁ320 for 2000KW (at 100% load)(can be +/- as dependant on the amount of generators running and their loads)
so if they can use 1/5 of the power as INPUT then they CAN have spare OUTPUT which if it is sufficient then it CAN power itself, obviously it can be unstable, unless you install a storage device..... ie a power pack for it so power is drawn WHEN needed and you can send the grid back the remainder of the power left... i should think thatll sort the 'unstable' power
Motor generators have a purpose, they can convert one form of AC to another amongst other things.
But they cannot create power, they always have a power loss across them.
Any generating system will not be 100% efficient, this would be against the laws of nature.
example:
If your are really going to be using 2MW then you will not be on a standard domestic tariff from the electricity supplier!
Reply to Phasing nightmare in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
