M
Michael Smith
You need a 4 phase board.
never knew they existed :/
if thatll sort the phase question i asked originally then thanks
would a surge suppression kit help with spikes if the only battery was the 12V and everything else was linked either by belt or by cable to one another?
You can't take a telling can you? IT WON'T WORK! IT REQUIRES AT LEAST 101% EFFICIENCY AND THAT DOESN'T EXIST!just throwing it out there again...... recirculating power source (itll power itself)
anyway, back to the topic, how can i make a power system that will do all power ranges between 200V and 500V
Amps of up to 200A
50HZ
and both single and 3 phase??
ah but a 12v starter only ignites the fuel so it doent need to be powerful enough to turn the engine because it doesnt.do the research....... i know for a FACT that a 12VDC starter CAN run a 48V alternator :/ all you need is the torque to turn the alternator..... which the starter can do as it can start 6L V8 diesel engines with ease
if you think im wrong then show a detailed calculation of how you came to the conclusion the 12VDC motor WONT be powerful enough to turn a 48V alternator at its required revolutions
With respect, that's a total irrelevance.do the research....... i know for a FACT that a 12VDC starter CAN run a 48V alternator :/ all you need is the torque to turn the alternator..... which the starter can do as it can start 6L V8 diesel engines with ease
it works by expanding gases when fuel is compressed/ignited depending on petrol or diesel
you clearly are not a trained mechanic :/
for starters.... a starter motor doesnt ignite fuel..... it only spins the engine fast enough for the combustion of the fuel/air mix to ignite, meaning the 'engine' takes over (starter 0-600RPM, engine 400RPM+)
the starter has to overpower the engine when the pressure gets to its peak.... ie at BTDC where chamber pressures will not be as great as when the engine is running through combustion but still pretty high and the faster the engine spins the higher those pressures get but luckily they will be met for a shorter period the more RPMS the engine is turning at
why do you think when you start your car up it sounds more like a 'pulse' than a smooth turning motion...... the drop is the high pressures 'slowing' the motor or.... putting load on it
it only spins the engine fast enough for the combustion of the fuel/air mix to ignite, meaning the 'engine' takes over (starter 0-600RPM, engine 400RPM+)[/quote ]
It would be unusual for a starter motor to turn the engine at anything like 600rpm - a couple of hundred would be a more probable max.
No, I'm not a trained mechanic but I've been a petrolhead all my life. There are very few parts on a car that I have not stripped down, refurbished, or replaced. Including grinding down cam follower spacers on my first car which had an overhead cam shaft engine. Developed from the Coventry Climax.
Sometimes this knowledge has been used - and abused. Unreasonable expectations.
Perhaps the worst was on my cousin's old Rover 75. One of the half elliptic spring rear leaf springs (think horse drawn cart) had a broken element. I replaced the entire spring. On my own. It needed a few strategically place jacks to relieve the tension so that I could remove bolts. It was challenge and a risky operation with the potential to get seriously hurt. It didn't make it any easier that it was outside on new years day, freezing cold, and snow on the ground. And all the others had baggered off to see a bl00dy football match.
I mention this not to blow my own trumpet - as I reflect back now it probably wasn't one of my most prudent undertakings. The point is I do know a bit about vehicle mechanics.
So give up with the bullshyte.
It won't work with me.
ok, next time your in the car, turn the key again when the engine is running, youll see that itll drop from about 800rpm (after the choke is off) to about 600rpm.... but i wouldnt advise this due to wearing both alternator and starter solenoid
Have you time warped here from the early 70s?
Sharp cookie!Hillman imp then ?
b) wouldn't be on here, instead probably on their own private island sat on the billions they have made in royalties.
its an underground house build with concrete NO bricks, more stable that way and more robust (added mesh) so in fact the above ground building will have a 10M deep foundation, possible of holding a 12 storey flat..... in theory.
it would be built in stages starting at the bottom..... foundation, then build the rooms from wooden boards and help in place with scaffold poles and whatever else necessary to hold it together during the curing and drying of the concrete around it (then removed, leaving concrete walls and ceiling), then the same again for the floors above, the only brickwork will be the above ground entrance and garage (plus the power house, which will have a fan on a flat roof to suck the air out and a filter membrane side wall for air coming in(length or the building))
i would include a picture, but i cant 'url' it to a picture on my pc :/
thats where you are wrong ...... the equipment is above ground..... the pool is below ground meaning itll need more 'power' to pump the water up
3 x 24KW heating pumps...... 72KW
2 x 3KW filter pumps...... 6KW Krystal Clear Pump and Filter Set 0.95hp pump with 7.9m3 per hour flow rate - Model 3 [Krystal Clear Pump Filter Model3] - £345.00 :
1 x water treatment monitor 3KW
5 x dehumidifiers 9KW Meaco 800i Range Pool Dehumidifiers [Meaco 800i] - £3,633.27 :
AT PRESENT, there is no way to make anything which is 100% efficient, let alone 500%. You can't fit a quart into a pint pot, nor can you get a quart out of a pint pot.
Sorry but there is no way to change the laws of physics. Not yet anyway.
Any motor / transformer etc gets hot, that's energy loss.
So if he put the transformer and motor in an insulated box they wouldn't loose heat :6:
...Or as an old science lecturer once said ..."boys,friction makes heat,yes?"..."Heat boils water,yes?"..."...so exactly how long would it take for donkey to ---- a bucket of water before we can all have a cup of tea?"...physics has an answer for everything :bow:
For free power, get a ginormous cage wheel and fill it with hamsters.
The trick is getting them all to run in the same direction.
