Guest viewing is limited
Hello EF,
My first post in a long long time,
I'm looking to swap out some tubes in a commercial unit that has a lighting control system in place, usual sort of stuff, some area's are dimmable via retractive switches and others are covered by absence detectors. All fittings are DALI controllable.
I have checked & double checked Philip's ballast compatibility tool & found the tubes I need which should work, however just wanted to reach out and see if anyone has any personal experience with doing this, and how well did it go?
Specifically, did anyone change any tubes in an emergency fitting & did it work? I had someone from their tech helpline answer this question, one said yes and another said no!
Tubes I'm looking at getting are the Master LED 1500 ones
Cheers
I think I would be honest with the customer and say.
Manufacturer has assured me they are compatible but just to be sure, can I do one light and 1 emergency fitting and leave them for a week before doing a large tube change project.
100% agree, I think if no one comes out and says 'yes mate nothing to worry about' that's the route i'll go down,
Cheers!
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The fittings cost the owner an arm and a leg so he didn't want to change the whole thing and just wanted the tubes replacing with LED. The cost of the LED replacement tubes would have been about £2.5k at the time.
I got 4 samples from the wholesaler (free of course) and fitted them to 4 fittings as a trial, within 3 weeks two had blown, we ran far far away from that job.
Surrey
Philips LED retrofit tubes & DALI, might this all go Pete Tong?
Thefailsafe2012,
oscar21,
