sjm
Hi guys, just a couple of questions.
First I seem to remember a local spark saying that you don't climb around in lofts whilst doing a PIR. Your thoughts on this please guys.
Secondly if you do go into the loft most houses will have 2.5 T+E for sockets on ring main probably under insulation. If the insulation is over 100mm what code should this be given?
Thanks in advance.
Steve
Thanks in advance.
Steve
